Pioneer PDP435FDE advice / opinions ?
Discussion in 'Plasma TVs Forum' started by stevedster, Jan 13, 2005.
  1. stevedster
    stevedster
    Jan 13, 2005
    1,132
    48
    Birkenhead
    +41
    Hey guys been looking for a plasma and have noticed that the Pioneer PDP435FDE is now only £2700 at my local Richer Sounds...
    http://ws4.richersounds.com/showproduct.php?cda=showproduct&pid=PION-PDP435FDE
    Now I think this is meant to be the 'best' if there is such a word, plasma on the market at the moment, and its meant to be HDTV compliant therefore future proof ?!?
    Could anyone who has one of these or knows about them give me any more info advice on this TV before I take the plunge ... i.e. whats it like with xbox, footie matches, also any issues with screen burn or any other problems?!? let me know guys cheers ;)
  2. jwramsay
    jwramsay
    Sep 7, 2004
    1,628
    West of Scotland
    +71
    Consider a 435-XDE if you can afford it.
  3. stevedster
    stevedster
    Jan 13, 2005
    1,132
    48
    Birkenhead
    +41
    hmmm, what are the differences?
  4. Mookie Blaylock
    Mookie Blaylock
    Jan 4, 2005
    15
    3
    and it's my first plasma screen so was nervous about spending 3K on a TV...
    I managed to pick up the screen, table top stand, speakers, dvr320s and a really nice Alphason stand from Comet for £3100.
    Not my ideal store to buy from, but when you consider the ticket price of the items were over £3650, I think I got a decent deal.
    As for the screen, it did take a couple of days to get used to the different type of picture vs a CRT, however, once I played around with it for a while, it did improve and has continued to do so.
    I would say that you have to be prepared to play around with the settings, if not, then don't bother, because I find myself changing settings very slightly all the time.
    I have my DVD connected via component and it looks stunning, Xbox looks fine, although I will be investing in a component cable to improve it further.
    The first thing I watched was football on Sky Sports, and to be honest, it looked terrible, but turning off all the processing settings made it loads better. Contrast and brightness levels really need to be tweaked to get it looking right.
    As for screen burn, I've probably been overly cautious with the screen so I've had no issues at all.
    I resisted going for the XDE as I was tight on budget and didn't need the PC input and other additional features.
    Overall, I'm very happy with it and would recommend it 100%
  5. stevedster
    stevedster
    Jan 13, 2005
    1,132
    48
    Birkenhead
    +41
    Cool, thanks for the info, I think i will be getting this plasma as it has had good reviews, also its future prooffor HDTV. So you dont use the scarts then? all componant cable?? could you not use the 'Xbox High Definition AV Pack' instead ???
  6. attach
    attach
    I also have fde and if you give it a good 200 hours to run-in you will be very pleased with the pq.
  7. ianrush
    ianrush
    Do you know how to access the service menu so I can sheck how many hours mine has been running? I have 345 HDE
  8. attach
    attach
    Put the unit on standby.Press the channel info button and wait 3-4 seconds. Then press left,up,left,right and then the orange button that puts the panel to standby. The panel should switch on displaying the service menu. Enjoy!
  9. ianrush
    ianrush
    Have tried it...20 times...when you say left,up,left right..you mean the buttons around the "enter" ?
  10. attach
    attach
    Yes i do and it DOES work I have just tried it :)
  11. ianrush
    ianrush
    and one button at the time? Not all together at the same time?
  12. cashlessbond
    cashlessbond
    Jan 1, 2005
    1,225
    Epsom, Surrey
    +45
    One button at a time. It is tricky and it does take a bit of time. I have done it on my 505XDE so it definately works. Although it took me a dozen attempts.
  13. jnrS3
    jnrS3
    Jan 7, 2005
    10
    ianrush,
    make sure you are pointing your remote at the sensor on the actual screen (bottom left on 435). I had the same problem until I pointed the remote directly at it. Hope this helps!
    oh and 435 fde - quality. Not had sky hooked up yet so can't tell you about that, but dvd and PS2 are excellent!
  14. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    You can get the XDE for £2740 from RGB Direct :)
  15. stevedster
    stevedster
    Jan 13, 2005
    1,132
    48
    Birkenhead
    +41
    so whats the difference between the XDE and FDE ??? thanks for that link too Nick ;)
  16. ianrush
    ianrush
    Have tried it 50 times now...I set the screen on standby..points the remote towards the screen..pushes the info button..waits for 3-4 seconds..then pushes the left, up, left, right..and pushes the orange button..and the..normal picture shows..not the service menu...
  17. jwramsay
    jwramsay
    Sep 7, 2004
    1,628
    West of Scotland
    +71
    HOLD the info button for 2 to 3 seconds!
  18. dave0523
    dave0523
    Dec 28, 2004
    261
    Somerset
    PC connectivity and PCMCIA card slot, if I recall correctly :lesson:
  19. ianrush
    ianrush
    Finally it worked! Thanx...but was it so difficult to say that I had to hold the button for 2-3 seconds? :thumbsup: Now I only need to be happy with the PQ on my pio 435HDE..because I'm not!
  20. jwramsay
    jwramsay
    Sep 7, 2004
    1,628
    West of Scotland
    +71
    Much more than that.
    Freeview Tuner
    Picture In Picture
    Silver Brushed Aluminium Remote vs Plastic one.
    Silver and Black Media Receiver vs Ugly Black job
    p.s. Still speaking to Tecwen Whittock? (Cough Cough)
  21. dave0523
    dave0523
    Dec 28, 2004
    261
    Somerset
    Ah, right, so very similar to our HDE's but less the FV Tuner.
    Must admit the brushed ally remote feels classy & looks nice.
  22. jwramsay
    jwramsay
    Sep 7, 2004
    1,628
    West of Scotland
    +71
    I too love the remote and was pretty shocked by the cost cutting when I first saw the 435FDE in Currys.
    BTW, Chuck, how many 0's in google again? :laugh:
  23. dave0523
    dave0523
    Dec 28, 2004
    261
    Somerset
    *cough* I don't know ;)
    The remote control, both in terms of looks and functionality is all to often forgotten or dismissed when buying a panel, it was quite important to me when I was looking around. Not sure I'd really want a black remote for my new screen.....
    Obviously I wouldn't have put it above PQ etc etc
  24. stevedster
    stevedster
    Jan 13, 2005
    1,132
    48
    Birkenhead
    +41
    well looks like i will be getting the slightly more expensive one then, might wait a few months tho see if the HD plasma market grows a little, tho i would be more than happy with the pioneer looking at reports i havnt read a single bad thing ! thanks guys :)
