Pioneer pdp435 hdmi input with analogue audio
Discussion in 'Plasma TVs Forum' started by dalli, Jul 25, 2005.
  1. dalli
    dalli
    I have my pc video output connected to the pioneer hdmi input 3 (using a dvi to hdmi cable)
    I have my pc stereo audio output connected to the input 3 analogue rca audio input.
    Now my problem is when I enable the HDMI input, it seems to disable the analogue audio input.I have even tried changing the HDMI setup option for audio source to analogue , and this does nothing. If you look at the PDP manual in the HDMI section, it shows a diagram of a device connected to both the HDMI input and the analogue audio input at the same time ,so I am presuming this is an acceptable configuration.
    Any feedback most appreciated.
