Pioneer pdp434hde
Discussion in 'Plasma TVs Forum' started by fully, Nov 24, 2004.
  1. fully
    fully
    Hi there I have a query with my pioneer plasma. It has a picture in picture feature however as I don't have an aerial and instead use a sky+ digibox for my tv picture when I use this feature I am left with a half static screen. Is it possible to change the settings for this so that I can for example see a dvd with picture from sky+ as well. Anyone's help would be greatly appreciated :lease:
  2. NC11
    NC11
    Sep 19, 2004
    465
    London
    +7
    you should be able to scroll through the inputs on the 2nd part of the PIP screen.
    just use the remote to move between the 2 parts and scroll through one of them to input 3 , where i suppose youre dvd is.
  3. jwramsay
    jwramsay
    Sep 7, 2004
    1,628
    West of Scotland
    +71
    Yes, use right and left to switch between sides and choose input 1/2/3/4/PC for each.
  4. trueson65@mac.c
    trueson65@mac.c
    hi fully, i'm gonna get pioneer 435hde tomorrow. Please tell me about quality. is This the best choice ...thanks
  5. fully
    fully
    Hi thanks for all your help it's a pretty good feature to have.
    Trueson65, to answer your question I have a pdp434 not a pdp435, I am extremely happy with it however and as it has been discontinued I got it extra cheap! :)
