Pioneer PDP434 and SKYHD Remote
kop1973
Anyone have an idea of how to set the sky HD remote to change my Pioneer 436 tv to input 3 when I push the sky button on the HD remote!?
Thanx in advance!
Gilly!
Not sure if you can go directly to input 3 but TV then HELP cycles through the inputs
kop1973
Cheers for that, was just hoping you could set it up to actually go str8 to the correct input. I know you can set it up with the Sony amp that I have upstairs to switch on and go to the actual correct input.
