Pioneer PDP433HDE + Bose 3-2-1 system
Discussion in 'Plasma TVs Forum' started by Amradicool, Sep 27, 2003.
  1. Amradicool
    Amradicool
    Any good?
    Whats it worth?
    Can you get better for cheaper?
  2. narabdela
    narabdela
    Nov 25, 2002
    270
    Glockamorra
    +5
    Cheaper than what ?
    Perhaps you should read this before buying any BOSE products.
    :nono: :nono:
  3. Amradicool
    Amradicool
    The package for £4900 inc speaker stands and installation.
  4. nathan_silly
    nathan_silly
    IMO if £5000 was my budget- I'll look at something with sound quality as well, not blow all on the display and then buy a bad sounding & cheap system (ie Bose, Sony DAV etc)
    Have you read that link given by narabdela
  5. RickB
    RickB
    The Pioneer is a great screen !!
    The Bose isn't a great audio system !!
    RickB
  6. Amradicool
    Amradicool
    So what would you recommend?
  7. RickB
    RickB
    Amradicool,
    Your screen is a great choice - I dont think anyone here will argue with it (I know I wont).
    As for the audio system - it entirely depends on what your requirements are - if space is an issue then that kind of means your limited to a satellie/sub combination - you could do far worse than Kef's eggs. If you have the space and the inclination then go for a full size speaker setup.
    What kind of budget are you looking at ?
    RickB
  8. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,885
    The Borders
    +3,117
    Amradicalcool
    01. Is it any good:
    The Pioneer PDP-433HDE is a 'good' Plasma TV the NEW PDP-434HDE is a much better PlasmaTV for just over £4K.
    The BOSE 3-2-1 is a bed side radio with some fancy processing and a lot of marketing to convince you that you can get something for nothing!
    02. What's it worth:
    Not £5K
    03. Can you get better for cheaper:
    Oh yes... lots of options.
    I'd look at a Pioneer PDP-434HDE plus the Pioneer NS-DV990 if you want a good quality Lifestyle system that looks, sounds and performs well and is near £5K.
    Best regards
    Joe
  9. Amradicool
    Amradicool
    Thanks,
    the budget is around £5000, basically my father has been critically ill and insurance has given us some money. During his recovery period (about 12 weeks) there is nothing he would like more than a good TV system. I know very little about high-end stuff, until a week ago we were looking at a simple widescreen. The main thing is we get it soon.
    So the Pioneer 433-HDE at £3900 is not what we should be getting?
    What about the surround system, we are looking for a satellite style compact system.
  10. Dutch
    Dutch
    Dec 5, 2002
    2,601
    2
    5
    North Yorkshire
    +284
    I would go for Joe's suggestion of the 434HDE - out in a couple of weeks. The NS-DV990 is a smart-looking sub/sat system which would be a good match for the plasma. I hope your father makes a speedy recovery.
    Steve
  11. Triggaaar
    Triggaaar
    Apr 13, 2003
    6,167
    +1,183
    As your father is after something NOW due to illness, if you don't fancy waiting a couple of weeks, you could either get the older pioneer you've mentioned, or a Panny. Depends what you like in you plasma - ignoring the latest models from Pio & Panny, IMO the current Pioneers offer better details than the Panny's, but not as good black levels. For me the detail of both is plenty good enough, but I don't like poor black levels (which all plasma manufacturers have to battle with) so I'd choose one of the Panny's.
    Do you want your plasma to be TV or a display?
    TVs will come with a tuner that makes there operation more simillar to normal TVs, and they'll have there own speakers, so you don't need to swith on a seperate amp to use them. But a display will be cheaper for the equivellant screen, and is a good option if you are using a digital box (sky or cable).
    As for speakers - I'd recommend looking at Gallos. Look nice (quite small), sound good.
    Have a look under Amps and DVD players for the rest of the kit.
    Hope that may help
  12. Amradicool
    Amradicool
    I have a Tosh 330 DVD player, would this be good enough for the Plasma tv?
    I was thinking to get just the TV, and keep it in the bedroom for my dad for now, then in a few months move it downstairs and get surround sound etc and hook it up to sky.
    Does the 433 come with speakers on the TV? How about the 434?
    Would the Plasma TV + a Tosh 330 DVD player be good, or does it really not do anything any justice?
  13. scott147
    scott147
    I have a Bose Lifestyle 28 system which I bought 2 months ago. Have I made a mistake?
  14. nathan_silly
    nathan_silly
    Did you pay more than £500 for it?
    IMO that's how much I'll pay for a complete Bose system- and yes I have heard them going. Kef Eggs & Ruark Vita's (and other decent satellite speakers) sound so much better
  15. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,885
    The Borders
    +3,117
    scott147 - not if your enjoying it! the Lifestyle28 is way better than the 3-2-1; for a kick off its actually got the required number of loudspeakers :)
    Amradicool - planning on turning your old man into a TV aholic then!
    Both the PDP-433HDE and the NEW PDP-434HDE have optional loudspeakers - the 434HDE has the added advantage of a sub out so if you want/need a bit of extra bass and don't want a full 5:1 system you can beef up the stereo speakers you get for the TV.
    Both the 433 and 434HDE have Pioneer's SRS sound - which basically tries to give you a wider sound stage (a bit like what the BOSE 3-2-1 is trying to do).
    I cant see why you cant use your Toshiba 330 DVD player with either of the HDE Plasma TV's - though I note you mention only getting SKY hooked up once you move the TV down stairs; if possible I'd go for SKY or a FreeView box in preference to an analogue TV signal in the bedroom if you can manage it.
    Best regards
    Joe
