Pioneer PDP-R06XE re-set
Discussion in 'Plasma TVs Forum' started by desertsled, Dec 31, 2017.
  1. desertsled
    desertsled
    Dec 31, 2017
    2
    4
    guildford
    I have a Pioneer media receiver pdp-r06xe with a "SD005" short on the speaker cable identified by the Blue LED flashing 5 times. Having disconnected all the speaker cables and powered down both the screen and media unit, then used the remote to restart the units it comes up with an error message about "internal protection unit turns off" then goes into stand by. Is there anything I can do to reset the units
  2. JayCee
    JayCee
    Jan 20, 2004
    23,991
    Lanarkshire
    +2,614
    It sounds like there's an electrical short inside the unit probably in the sound output stage.
    It requires troubleshooting by a technician.
  3. desertsled
    desertsled
    Dec 31, 2017
    2
    4
    guildford
