Pioneer PDP-LX5090 with 8 red blinks – Repair
Discussion in 'Plasma TVs Forum' started by rosherman, Dec 5, 2018.
  1. rosherman
    rosherman
    Dec 5, 2018
    Israel
    My Pioneer PDP-LX5090 (manufactured in UK, 2008) has the following issues:
    1. After watching TV for a few hours (~2-3 hours) it suddenly turns off and the red indicator light blinks 8 times, stops for a few seconds and starts blinking again (8 times) and so on.
    2. If I disconnect it from the power supply, and after 2-3 minutes I connect it. When I try to open the TV it feels like it starts (the blue light is on) but after a second it turns off and the red blink starts again.
    3. When I disconnect it from the power supply and then wait a couple of hours and then re-connect it, the TV works again.
    Appreciate if someone here can help me with this problem.
  2. Ivor_Biggern
    Ivor_Biggern
    Nov 6, 2003
    2,311
    +136
    I've got a similar issue, it's with the sane model tv. Mine doesn't power on though, it blinks 8 times and won't turn on. Mine is 8 blue blinks, not red.
    Can anyone tell me what options their are to get the problem fixed, I live in Cheshire.
