Quantcast
Pioneer PDP-LX5090 updates
member 577815
My tv is checking for updates every day but doesn't seem to actually update anything and the message keeps appearing on the screen, which is annoying. What does it actually need to be connected to as at the moment it's just the sky +HD and Blu Ray?
member 577815
The message says "checking for new software and new channels will be carried out". I press ok, but the same message appears day after day. Any suggestions?
Bassman1
i think its somthing to do with the digital tuner for freeview? i used to have the same issue on my 508, from what i remember i had to go into the menu and switch DTV of or somthing along them lines?
member 577815
Thanks. I'll give that a try. I don't have an aerial connected to the tv so I guess it will always be checking for new channels, if it's to do with the dtv.
