Pioneer PDP 508XD vs newer Pannys
avcar
Hi all ive been offered a Pioneer panel used with no speakers, i know this is an older set and not full 1080p think its a 720 will i notice much difference i watch 720p movies is there a massive difference between this and the new panasonics for around £1k?
cheers
bladedripper
Suspended
If its in good condition id snap it up,fantastic tv that will walk over any panny on sd and will also be nice for hd.:smashin:
avcar
how does it compare with the newer pannys? would you say still better even though not full hd?
bladedripper
Suspended
I would not worry about the full hd,ive seen both and you would be hard pressed to see a difference.:smashin:
jayden28
I had the 42" pioneer 4280xd and i currently have the G10 and the G10 was without doubt the better set for HD,i always found the pioneer on the soft side next to the G10.
