Pioneer PDP 505XDE
Discussion in 'Plasma TVs' started by Scarface13, Dec 4, 2004.
  1. Scarface13
    Scarface13
    Hi is the pioneer going to be compatible with SKY HDTV HDCP thingy? Also does this model suffer from the lip sync issue?
  2. Moviebuff
    Moviebuff
    Aug 10, 2004
    2,019
    Southampton
    +236
    As is the 504 before it,this model,by virtue of being equipped with HDMI,along with the necessary HDCP,should have no problems with the proposed upcoming Sky HD service.
    My 504 suffers very slightly with lip sync - not sure whether the 505 is any better.
    HTH
    Jerry
  3. Scarface12
    Scarface12
    Phew at least I know now that my huge expense will be a little bit more future proof.
  4. aarontp
    aarontp
    Nov 17, 2004
    159
    Northampton
    +7
    I have not had any lip sync issues with my 505 model. Just a slight jagged edge on screen when watching Sky +. Other problems with mine see - http://www.avforums.com/forums/showthread.php?t=168324
