pioneer pdp-43mxe1
Discussion in 'Plasma TVs Forum' started by mods, Nov 2, 2004.
  1. mods
    mods
    Oct 25, 2004
    44
    11
    Has anyone seen above plasma in action? is it good?
    :) cheers
  2. Vinesh
    Vinesh
    Dec 23, 2002
    776
    28
    +31
    I have one.
    Been using for a couple of months. The screen is really with all the connection required.
    I brought mine from Joe.
  3. mods
    mods
    Oct 25, 2004
    44
    11
    cheers mate would a js scart 2 vga converter improve sky picture on the pioneer
  4. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    How else would you connect it? Composite is the other option, so absolutely it would. They work well with pioneer, but note you have to have a video card installed before it will work, or at least you did on the 433mxe, I'm assuming that is the same.
  5. NonPayingMember
    NonPayingMember
    Previously Liam @ Prog AV
    Oct 18, 2002
    8,523
    Kent
    +830
    Yes is same - video card required to do pretty much anything except send basic PC signal!
    MXE1 is gorgeous screen, that or Panasonic PHD7 are pretty much the only high res 42" options to go for. New NECs out soon (42XR4) will likely be another option well worth considering
