Pioneer PDP-436XDE speakers
Discussion in 'Plasma TVs Forum' started by sct21, Aug 4, 2006.
  1. sct21
    sct21
    Jul 2, 2006
    New to all this and wondering if anyone can help?
    Just bought a PDP-436XDE - can the sound be put through my (old) sony davs800 home cinema speakers or should i have bouth the pioneer speakers?
    Also any additional info would be appreciated on best way to connect the davs800 , sky and the plasma
    many thanks
    Scott
  2. Bacus
    Bacus
    Dec 30, 2004
    8,994
    Close to the sea
    +2,924
    yes you can use your old speakers, but the pioneer ones are very good !! I am more than happy with my pioneer speakers for sound. As to hooking up sky, well use input 1 on the media box and make sure your sky box is set to output RGB :smashin:
  3. D65
    D65
    Mar 20, 2006
    440
    netherlands
    +24
    I can recommend the pioneer ones too, although I have the single middle speaker, under the screen.
  4. Gilly!
    Gilly!
    Jun 15, 2006
    141
    Peterborough
    +5
    I have a spare set of Pioneer speakers in the original packaging that were only on the set for a couple of days whilst awaiting my amp - if you are interested I can put them up for sale via the forum.
