Pioneer PDP-436XDE Owners - a quick question
martinedwards
Just been looking through the PDF manual for this TV, which I'm considering, and I have a quick question - is it possible to renumber channels in the DTT EPG?
Where I am, my current Freeview box tends to pick up the weaker BBC1 etc. and number is "1" instead of the correct one from my local transmitter, which it usually numbers something like "801". I have to manually go in and renumber the correct BBC1 channel to "1". Can the same be done on the Pioneer?
I see from the manual you can set channels to "skip", but presumably that would leave me with the incorrectly numbered channels. Can anyone elighten me?
Trending threads
