Pioneer PDP-436SXE
P
penandpaper
I would be intrested to hear peoples thoughts on the Pioneer PDP-436SXE I'm thinking about getting one been quoted £2,094.99 locally or £2,300 with HD DVD Player and Wallbracket.
What do you guys think about it? Or could i do better for that kind of money or less?
Pioneer PDP436SXE
1x HDMI (High-Definition Multimedia Interface) Digital Link for direct connection to HDMI enabled devices
One Body Design (No Media receiver needed)
Supplied with table top stand and speakers
6th Generation Pioneer Panel
Ready for High-Definition TV
Large 43-inch Screen
Pure Drive 2
PureBlack Crystal Layer technology
New Deep Waffle Rib Structure
Direct Colour Filter
i-CLEAR Drive Colour gradation enhancement
Multi-step 3D Y/C filter for PAL
Digital CTI (Colour Transient Improvement)
Digital Terrestrial ( FREEVIEW ) & Analogue Tuner
Freeview Electronic Programme Guide (EPG)
MPEG Noise Reduction
Child Lock
Split Screen & Picture in Picture Modes
Colour Temperature Adjustment
160-degree Viewing angle
2100 page teletext memory with level 2.5 support
PAL & NTSC Progressive Scan Compatible
Dolby Digital Bitstream Output for future proofing
Thanks for any help
Always-hungry
If your not wall hanging, have a stand and an Av amp you wont do any better, cracking tv :)
P
penandpaper
thanks for the feedback, is the price any good?
£2,094.99 for the screen
OR
£2,300 with HD DVD Player and Wallbracket. - think i can switch to a stand.
Will go down and get it in the morning with a bit of luck then :)
StevePn
Sorry to Hi-jack this thread but a quick question for:
Always-hungry
Just about to get a DVD and looking at the Samsung H950. How do you like it? Pioneer are about to bring out a new range of DVD player with HMDI outputs for about £150, so not sure whether to wait and see or buy a H950.
Also what settings are you using for the SXE?
Steve
Podcast: Reported HDMI 2.1 bugs, Audiolab Amp & LG LED Projector reviews + Best of the Month
