Pioneer PDP-435XDE - Little Black Feet....
Hudson
Can any owners of this set please tell me if the screen comes with a set of ''little black fee'', this is how the customer services guy at Pioneer described them. He tells me that these will support the screen and if i do not wish to spend the £200 on a table top stand i don't need too. But a dealer tells me no..... spend the cash... i really could not care less how the panel stays up right on my Alphason av stand... but i do not want to spend £200 on a stand when i could get something just as useful with the screen.
Also are you aware of any lip sync issues with this set...i seem to hear about others but not this one. Well only apart from the buzzing issue :)
phcahill
Did you have any luck with getting little feet. I'm vertically challenged and do not want to add height to set screen! It will foul a mantlepiece.
Paul
MAW
You don't get feet with XDE's IIRC, they come with MXe's. Just off to install a FDE, I'll correct this later if needed! I do have boxfulls of black plastic feet from MXE's here, you'd be welcome to some for the price of a stamp, but not at all sure they'd fit, the edge profile is completely different. I'll look today.
phcahill
Thanks for the replies. I've hopefully taking a Sagem DLP back to Comet today. If all goes well I'll be buying an XDE.
Paul
