Pioneer PDP-4350 Installation
Discussion in 'Home Cinema Building DIY' started by tee2nu, Apr 2, 2005.
  1. tee2nu
    tee2nu
    I am new to this site and wanted to know if anyone has installed a Pioneer PDP-4350 over a fireplace? I want to place the Media Reciever cable behind the wall. My problem is how do I make it aesthetically pleasing where the media receiver cable goes in and comes out? All the wall plates I've seen are only for HDMI or DVI connectors and the pioneer has a proprietary cable. Any help is greatly appreciated. Thanks!! :lease:
  2. MitsiTurbo
    MitsiTurbo
    Jan 6, 2005
    940
    28
    Milton Keynes
    +82
    We have ours mounted over our existing fireplace and the receiver in a fitted cabinet at the side. The installers fitted a 3m umbilical cord (DVI and another 2 connections, cant remember what they were though im afraid!) before any work was started and it was then plastered over - leaving a length in the cabinet, and another length coming out of the wall where the screen is positioned
    Hope this helps
