PIONEER PDP-435 XDE PLASMA AND PC's
Discussion in 'Plasma TVs' started by rio_cs, Oct 10, 2005.
  1. rio_cs
    rio_cs
    Oct 10, 2005
    24
    4
    I am thinking of buying a PDP-435, or PDP-436, and I want to use it with my PC for browsing and some gaming. Anybody had any experience or does anyone know of any potential problems. Thanks
  2. FaxFan2002
    FaxFan2002
    Jan 25, 2003
    2,115
    63
    Andover
    +109
    I've tried a few laptops and everything seems to be ok
  3. kamaran
    kamaran
    Jul 20, 2002
    688
    +24
    Does anyone know if screen retention is a big issue with using your plasma as a monitor (ie Windows Taskbar/logo's etc)?
  4. chedmaster
    chedmaster
    Jan 29, 2005
    2,654
    68
    +28
    it can be difficult if you plan to use a digital connection (i.e. DVI to HDMI) as the HDMI port is designed for video, so there is naturally quite a lot of overscan - usually enough to half lose or completely lose the taskbar. VGA should be fine :)
  5. rio_cs
    rio_cs
    Oct 10, 2005
    24
    4
    mmm thanks m8. That may be a problem coz I think the 436 only has a front VGA connector on the media box and I dont want a VGA cabling dangling out the front.
  6. Radioactive__Man
    Radioactive__Man
    Jan 13, 2001
    948
    Scotland
    +18
    I hooked up my PC via front HD15 within a week of getting my 435xde last year, results were impressive, but it was removed within 3 days due to image retention of the explorer top nav bar, which subsequently cleared after a few hours normal use
    my feeling was it wasn't worth the risk
