Pioneer PDP 434PE without mediabox, direct with DVI
Discussion in 'Plasma TVs Forum' started by tombates, Sep 6, 2012.
  1. tombates
    tombates
    Dec 30, 2008
    107
    +3
    I found someone offering a cheap Pioneer PDP 434PE without a media box.
    I was reading around the internet and apparently you can connect a pc straight to it using a DVI cable and it will work without the media box.
    Is this true?
    Or do I need a media box
  2. tombates
    tombates
    Dec 30, 2008
    107
    +3
    Apparently it can but the TV I found has green red constant lights and needs the trap switch resetting which you cannot do without a remote.
