Hi peeps, it appears I have locked my pionner up by activating the trap switch... long story, but heres the short version
Bought a pdp436 + mediabox for £50 with a cracked screen.
Tried the mediabox on my pdp433 and it didnt work
Tried to see if my 433 screen would fit in the 436 (hence remove the 433 backpanel)
Tried to see if the mediabox would work again with different leads with back panel off, this tripped the trap switch.
It appears its now in safety mode or something and I need to enter a code via the remote to being it back to life..
I have searched and searched and the only thing I can find is Menu / Enter / Power .. this has tried been entered 100's of times (honest it has).
The symptoms are a rapidly flashing standby light on the tv (about 3 times a second) theres no pause and from what pioneer manuals I can find this sounds about right.
can anyone offer me any other advice or if its possible to bypass this safemode by wiping a eeprom or something ?
anyhelp out there ?
thanks
Steve
anyhelp out there ?
thanks
Steve
