Pioneer PDP-427XD remote - button for DVR 545HX EPG doesn't work/exist?
B
buckleyp
Just got a PDP-427XD and DVR-545HX-S.
One annoying problem...the remote on the DVR is very basic, but the one for the TV is OK...it's a multi function remote so I can select TV, STB, DVR and VCR.
In the DVR mode it can control just about all the useful features of the DVR, EXCEPT I cannot pull up the EPG or Guide+ on the DVR so I have to use the basic remote control if I want to record anything.
On the 545 remote there are 2 buttons marked Guide and Disk Navaigator/dvd top menu.
On the 427 the equivalents are Disk Navi and Top Menu/Guide however the latter does not pull up the EPG, just the top menu on DVD mode and the Disk Navi again in HDD mode, so that's 2 buttons that access the Disk Navi and none to access EPG on the DVR...most annoying!
It seems a discrepancy between the 427 and 545 remotes.
Does anyone else have the same problem? can it be fixed? is it a fault?
many thanks in advance.
Paul
