Pioneer PDA-H03/WL extension cable
g7mfo
Hi All
I'm after the cheapest place to buy a 7m or 10m Pioneer Extension cable. Are these cables extensions cable which connect to the original lead or 'complete' leads?
Has anyone un-soldered the plugs to feed the cables down conduits in the wall the resoldered the conections?
Do not fancy re-plastering again!
Thanks Richard
Joe Fernand
AVForums Sponsor
Hello Richard
The PDA-HA03/WL is poorly described as an 'extension' cable - it is in fact a replacement 10.0m cable.
Retailing this cable at around £190.00 puts just under £20.00 in the profit column - so no dealers going home with a big smile after selling one of these cables :)
Dont even attempt to unsolder the connections (they are moulded) on your 3m cable - if your brave you could cut it in the middle and extended it; not a job for the faint hearted or impatient; and will most likely result in signal quality drops.
Best regards
Joe
MAW
You're right Joe, I've had a sad and traumatic experience with this on a 503HDE, after falling foul of the description about a week after they came out. Do not cut the cable, bite the bullet, and pay the money. It's essentially a DVI cable, and at 10m, it needs all the quality it can get.
g7mfo
Thanks MAW & Joe
It look like I'm going to have to get the Chisel and hammer out. It's a shame, I had put two conduits in the wall for the AV cables.
Thanks Richard
