Pioneer Pal Prog
Discussion in 'Blu-ray & DVD Players & Recorders' started by Irish1, Feb 23, 2003.
  1. Irish1
    Irish1
    Feb 13, 2003
    35
    Carlow Ireland
    Is there a Pioneer DVD player that has pal prog scan??
    If not I was told by a few ppl that the Pioneer 656a would produce a better picture than some cheaper players with prog scan.
    I will be using it on a AE100 projector will I be missing out on a lot by getting the 656A without the prog scan???
    Thanks:confused: :confused:
  2. James45
    James45
    Sep 21, 2002
    2,844
    59
    Taking Care of Business
    not yet there's not i would expect its inclusion in the next line up of model.
    the 656 is stunning and while the pq will be better than a lot of cheaper prog scan players you'll still suffer from jaggies.
  3. Dutch
    Dutch
    Dec 5, 2002
    2,601
    2
    5
    North Yorkshire
    +284
    If you want an NTSC prog scan 656A, you could always import a U.S. spec one from www.jvb.nl This would actually work out cheaper than buying a U.K. spec player in the U.K. :smashin: You would miss out on the SACD feature, but would gain PS, which is nice! ;) Your other choice would be the 757Ai which again has NTSC prog scan, with DVD-A and SACD and featuring FireWire audio outputs. The 757Ai is a superb player and is available for about £630 MR modded. Hope this helps.
    Steve
