Pioneer or Yamaha budget AV
StevieDvd
Joined
Dec 27, 2003
Messages
1,378
Reaction score
151
Points
299
Age
68
Location
Stevenage, Herts
Am going to return the Panasonic SA-XR15 to shop in next few days and wold appreciate feedback on its replacement.
Have the Yamaha HTR5640 or Pioneer VSX-C301 in mind.
Pioneer as the connections are scart including rgb
Yamaha as it has component (is that better if I only have rgb scart out on DVDR & NTL box)
Steve
May I ask why you are returning this unit. I have seen rave reviews from owners about this new Panasonic digital amps.
Are they all they are cracked up to be?
I bough the AV to direct the audio from NTL, DVDR and TV through a 5.1 speaker setup. I was looking at the Pioneer as it controlled the audio & video switching, has rgb in/out and the digital input.
The Panasonic SA-XR15 is cheaper and only has composite video so at present I only use it for audio. The missus is confused enough with the many remotes and I wanted to make it easier to select the audio/video.
You should see the confusion when the video signal is not the same as the audio.
Willing to spend a bit more but as I'd be switching it at Richers that limits my options.
To be honest only the Pioneer seems to do what I want. The Yamaha has 2 rgb component in but only one out. I think that means if I feed the DVDR and NTL box in via component either the TV or DVDR would use the 1 component out and the other would have to use a composite!
It's all making my head hurt!!!!!!!!
Any suggestions? My 14 day trial period is going to end soon.
I find it hard to believe that the 'cheaper' Pioneer 301 has more rgb ins/outs than the Yamaha.
Am I just being stupid and missing the correct connections?
Have seen that 2/1 component in/out seems standard. So how would on connect NTL scart out(rgb), DVDR scart in & out(rgb) with scart tv (rgb) using say the Yamaha HRT5640 (or next model up)?
Steve
Sony BRAVIA 9 Mini LED TV: The Best HDR TV EVER?
Back
