pioneer or arcam?
Discussion in 'Blu-ray & DVD Players & Recorders' started by dexter, Apr 24, 2004.
Tags:
  1. dexter
    dexter
    Jan 27, 2002
    212
    I have the chance to get either a Pioneer dv757ai dvdplayer or an Arcam dv89. I know these models have been around a while and have been replaced (or are about to be) but I quite like the look of them.
    My current player is a Pioneer dv737 which has been great but I am now looking for Pal progressive (which the 737 does not do) and DVDaudio.
    As far as I can see the Arcam used to cost more (about £1300) but the Pioneer has the benefits of SACD and i-link.
    I would like to use the player as a cd unit as well.
    Any preferences?
    Thanks!
  2. buns
    buns
    Apr 29, 2001
    6,094
    58
    Belfast
    will you use the i-link? Do you like your current player..... if it had pal prog would you be happy?
    ad
  3. dexter
    dexter
    Jan 27, 2002
    212
    yes - if PAL progressive was available for the 737 then I would probably stick with it for a little longer...
    you have intrigued me...
  4. buns
    buns
    Apr 29, 2001
    6,094
    58
    Belfast
    well if you are happy short of prog scan, the obvious answer is the pioneer player. After all, its going to be an improvement along the same basic lines as the machine you already have..... which you are already happy with.
    Taking the arcam would introduce a whole different perspective that probably is not worth considering if you are already happy.
    all the best
    ad
  5. floatingkiwi
    floatingkiwi
    Sep 8, 2003
    134
    Taupo, NZ
    +5
    If you're going to use it as a CD unit as well, obviously the Arcam would be lots lots lots better. It's going to be lots more expensive as well...
  6. rkb
    rkb
    Oct 7, 2003
    698
    Irvine Scotland
    +33
    Arcam DV89 available from £499- see threads in Special Offers forum. Unbeatable at that price- and would win hands-down on CD replay.
    rkb
  7. ResB
    ResB
    Feb 10, 2004
    UK
    +7
    I went through a similar issue last week....is it the Pioneer DV-868AVi-S or the Arcam DV79....
    Pioneer won this one as it was SACD and DVD-A as opposed to just DVD-A like the Arcam. (Arcam looks significantly better though) :)
  8. chris
    chris
    Nov 20, 2000
    1,216
    romney marsh, kent, uk
    +28
    The arcam will also play most SACD's, but only in stereo.
    So it would depend weather you like multi channel music.
    I changed from pioneer to denon, then to arcam.
    I still have a pioneer 565, which is said to be ( by some mags) quite good at CD replay, but my Arcam 89 makes it sound like crap.
    I could never really tell much difference between my other players, each one sounded better as i changed them, but after compairing my arcam against my 565 in the same room, side by side, the arcam is brilliant.
    I've evern started buying CD's again...:)
  9. buns
    buns
    Apr 29, 2001
    6,094
    58
    Belfast
    the dv89 is actually £599 not £499 as suggested (this is for the dv88+). This would be my choice of the two suggested, however if Dexter is happy with what he has (excepting the pal prog) then without being able to demo the dv89, the pioneer would be the wise choice. Of course if possible, demo them both and find out :)
    ad
  10. rkb
    rkb
    Oct 7, 2003
    698
    Irvine Scotland
    +33
    You're right buns:blush:
    DV89 £599
    DV88+ £499
    rkb
  11. gringottsdirect
    gringottsdirect
    Jan 11, 2002
    2,905
    71
    50 Rue St Georges, Paris.
    +32
    I'm sure you meant that to read Arcam will play CD layer of Hybrid SA-CDs.
    Arcam can't play DSD layer of SA-CDs. :cool:
  12. SL Boy
    SL Boy
    Mar 11, 2004
    36
    I am currently going through the same Pioneer versus Arcam process. Auditioned the 868 and found it lacking smoothness on CD replay. Waiting to audition the DV79.
  13. dexter
    dexter
    Jan 27, 2002
    212
    Can you let me know what you make of the 868 v 79 comparison?
