Pioneer NSDV1000 any good?
Discussion in 'Home Cinema Buying & Building' started by mattscholey, Nov 10, 2004.
  1. mattscholey
    mattscholey
    I'm seriously looking into buying the Pioneer NSDV1000 for DVD Audio and Super Audio CD (SACD) playback. If you know this model, would you recommend it to me for this purpose?
    I have read that when playing stereo sources the subwoofer is not active, and so the sound lacks bass. This is an important flaw, as I do wish to use the systems for DAB and CD. Is this subwoofer thing true, or is there a way of bypassing it?
    Also, is 5-channel stereo (Dolby Pro Logic 2) any good for music? Does it "enchance the stereo sound" or just make a well mixed CD sound down-right weird?
    Thanks in advance,
    Matt
  2. jaymac
    jaymac
    Jan 15, 2003
    1,725
    63
    North Somerset
    +138
    I have the 99 and the sub is not inactive in stereo. But you cannot change the sub mode ie., cinema/p-bass etc., when playing sacd or dvd -audio Personally dont find this a problem As for p/logig2 it can enhance some music better than others.Wouldn't say there is a pattern a case of try and compare but its never weird. I source FM stereo a lot and some material can be excellent.don't know about dab but if freeview dig /radio is anything to go by I'll stick to FM
    In case you dont know you can download the manual for the 1000 from pioneers website
    cheers
    Jaymac
