Thinking of getting above system for largish room Like the look of the tall boy thin NXT speakers etc May mount on wall at later stage etc Has anyone any knowledge of these for Sound quality? (Got awards for Stuff magazine etc...) Other option was the slightly cheaper (more dated) Panny SCHT900 Probably about £100 cheaper! Is the DV990 worth the extra? ANy info would be powerfull! Cheers
i too am considering the DV990.. just returned the DV99 to Richer Sounds because of what looks to be a recurring fault with the speakers. i don't think this fault (the grills coming off when not supposed to) can happen with this system by the way the speakers have been built. apart from that I thought the system was excellent, the player (same one as the 990) accepted everything i tried to play on it and the speakers provided more than ample power. i've just moved to a house with a larger living room and so could take the tall boy speakers.. saves on stands too! would appreciate any opinions from 990 owners
also.. panasonic are releasing the scht870 which is supposed to be upgrade version of 900.. they've got it on www.avland.co.uk
I got the 990 today and it seems pretty fantastic to me. Find a review here http://www.whathomecinemamag.com/cgi-bin/displayreview.php?reviewid=3938
