Pioneer MXE1 calibration with DVE
Discussion in 'Plasma TVs' started by Mantorok, Sep 25, 2004.
  1. Mantorok
    Mantorok
    Hi All,
    Last Wednesday I became the proud owner of a PDP-43MXE1 thanks largely to the favourable comments in this forum. I'm pretty happy with it overall but I'm having trouble calibrating it with Digital Video Essentials (PAL edition).
    The main problem is with setting the Black Level (Brightness) using the test pattern supplied on the DVD. Its the one with a grey scale in the centre of the screen and 3 vertical stripes on either side representing levels of black below and above "video black" (or something like that)
    Anyway, I can just bearly make out the centre vertical strip, the other 2 are not visible. This makes it rather hard to following the instructions on the DVD to set the brightness control.
    I don't believe its the DVD player's fault as I've successfully used the same player to calibrate my old Sony CRT with great results. The only difference this time is that I'm using component cables (Tara Labs 203V) instead of S-Video
    Can anyone help me out here? I'd like to know what other MXE1 owners have set their picture controls to (ie. Contrast, Brightess, Colour etc) .
  2. Mantorok
    Mantorok
    Has no MXE1 owner calibrated their display?
    Even if you haven't please let me know what your picture settings are.
    Also, what are all those other settings for such as DNR, MPEG NR and CTI. The manual doesn't explain what they are at all.
    Any advise for optimising the picture quality would be useful.
    TIA...
  3. Gordon @ Convergent AV
    Jul 13, 2000
    13,983
    +2,787
    Well I know of at least three other instances of this so I guess there is an issue with the Pioneer input board. I'd speak to your supplier and get them to fix it.
    Gordon
  4. Mantorok
    Mantorok
    Thanks Gordon,
    Can you please confirm that the MXE1 should be able to display the "4% below video black" strip on the DVE black level test pattern?
    Another odd thing I found with this display is that it already had over 500 hours on the clock before I took possession of it. Pioneer don't "run them in" do they?
    Cheers.
  5. Gordon @ Convergent AV
    Jul 13, 2000
    13,983
    +2,787
    When you use the VGA or DVI inputs with an external scaler you can see all the black detail. When you use the input terminal board you can't. They might say it's supposed to be like that but I'd suggest that it is a broken design if that's the case.
    I have no idea if they burn them in. My old MXE had about 5hrs on it I think when I got it.
    Gordon
  6. stewwy
    stewwy
    Sep 13, 2004
    26
    3
    DNR == Dynamic Noise Reduction
    MPEG NR == MPEG Noise Reduction ( ie Noise reduction when showing MPEG files I think)
    not a clue on the last sorry !
    try them on and off and see which is best
    good source, good connects == best off
    either bad == they may improve picture but if you've audio lag they'll make it worse ( more processing )
    stewwy
  7. Triggaaar
    Triggaaar
    Apr 13, 2003
    5,571
    +1,016
    I'll post my settings at some point - won't be entirely useful, as mine are via Lumagen, but will give you an idea of what to look at.
    As Gordon's said re the input board vs DVI input.
    Not sure why your unit had 500 hours, mine had 1 (which was while Joe was setting it up).
  8. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +412
    Dare we ask where this unit came from? 500 hours sounds a lot. Was the video board installed? Was the screen 'shrink wrapped' and was there any evidence of paint scratching on the back, ie could someone have previously fitted a wall bracket? This smells iffy. A good explanation is needed for 500 hours. No manufacturers run in their screens for you, on 1st turn on, you would expect to see 2 turn ons and 10 minutes, unless Joe or other kind dealer has installed the card for you, and pre set the right menu otions for your setup.
  9. ianh64
    ianh64
    Aug 7, 2004
    2,233
    SW London/Surrey borders
    +63
    Slightly off forum, but related.
    I can't see the 4% below black with my combination - Meridian G98 (at black level of both 0 and 7.5 IRE) and Loewe Xelos 32 SL LCD using HDMI->DVI-D. Its there when using component, just not visible when using digital input. Is this a problem or would you not expect to see 4% below when the screen is properly calibrated. Unfortunately I am not sure whether the Loewe is using DVI-PC or DVI-Video levels - if anyone knows, please let me know.
    I understand that the Meridian is using DVI-video levels so could this explain the lack of 4% below if the Loewe was expecting DVI-PC levels?
    Ian
  10. Repo
    Repo
    Jul 21, 2004
    430
    Sheffield, UK.
    +21
    That's far from new - if you paid for a new one then demand a new replacement; I certainly would.
  11. Triggaaar
    Triggaaar
    Apr 13, 2003
    5,571
    +1,016
    When a system is properly calibrated, you shouldn't see anything below std black, but by slightly increasing the brightness, you should see below std black (that's the way to tell you've calibrated to the right point).
  12. ianh64
    ianh64
    Aug 7, 2004
    2,233
    +63
    Thanks Triggaaar
    Thats what I had concluded but couldn't get it confirmed. Not sure if it was, as Joe Kane explains, a 'design fault' that would prevent proper calibration. Interesting to know if this is common to all DVI-Video/HDMI level inputs. It would make sense if it was due to the DVI-video range being 16..235 rather than 0..255 for DVI-PC level. I just need to find out whether my Xelos expects PC or Video levels.
    -Ian
