Pioneer media boxes
Discussion in 'Plasma TVs Forum' started by andybryant, Nov 16, 2003.
  1. andybryant
    andybryant
    Dec 30, 2002
    9
    Bishop's Stortford
    Hi there,
    Last time I was looking at Plasmas, I was looking at the previous generation of Pio (433), and Panny (series5). At the time, the Pio with media box was terrible in comparison to the Pio without. So I was all set to go with the Pio standalone version.
    Some time passed.
    I'm now back, and I've seen the new Pio 43" with media box (434-HDE), and it looks fantastic. I can't fault it. I understand from my local dealer that there is a non-media box (434-MXE?) varient due out in Jan/Feb.
    They've obviously done some serious work on the media box. Have they improved it to the state where it is now pointless waiting for the non-media box version? If I feed it with a digital input from a HTPC at native resolution, will it pass it through to the display un-affected?
    Now - how to get a digital feed from the HTPC to the display? I've got a DVI o/p from a Radeon card. Could I connect this to the HDMI on the back of the media box?
    I think the connection to the display is DVI. Could I feed this direct from a HTPC anyway?
    Cheers, Andy.
  2. lumpsucker
    lumpsucker
    Nov 18, 2002
    411
    Cornwall
    +15
    Hello Andy,
    that is a good question. The Pioneer guy I met last Wednesday was claiming that this would not be possible becuase of the lack of HDCP compliancy on a PC DVI interface.
    For my part I think that by using a DVI-HDMI adaptor cable (available in the states but I can't find any available in UK yet) the connention will be possible provided you can set it to a refresh / resolution that the 434 will be happy with. a look on the U.S. forum should provide the answer very soon. I'll let you know if I find out anything.
    Simon
  3. Costas
    Costas
    Jan 14, 2003
    1,663
    63
    Swindon, UK
    +120
    I had a 433HDE and now a 434HDE. The 433MXE was always better than the 433HDE. The new 434HDE looks better than the 433MXE. A 434MXE new version is expected next year.
  4. jspink
    jspink
  5. lumpsucker
    lumpsucker
    Nov 18, 2002
    411
    Cornwall
    +15
    Thanks jsspink,
    I've emailed the UK contact address to see if they will play ball.
    Simon
  6. sparkymarky
    sparkymarky
    Dec 12, 2002
    1,071
    48
    cornwall
    +32
    i thought the mxe and hde were the same panels, only difference is one has a tuner box?
  7. lumpsucker
    lumpsucker
    Nov 18, 2002
    411
    Cornwall
    +15
    Mark,
    There is no spec that I have seen for the new 4th generation MXE but the 3rd generation HDE and MXE were very different beasts. However, as per your other thread I would avoid the 433HDE because it had the naffest of media boxes. If you could pick up a 433MXE for £2K then that would be a good deal.
    Simon
  8. alwyn
    alwyn
    Dec 10, 2002
    562
    west country
    +13
    The reason for the big improvement in the new pioneer media box and consiquently the panel is that the box is now made by pioneer the previous one was made by sharp and was not very good,one big omision being no progressive scan now included in the pioneer box
  9. lumpsucker
    lumpsucker
    Nov 18, 2002
    411
    Cornwall
    +15
    bit of a cornish thing goin on 'ere my 'andsome ?
