? Pioneer Media Box connections
Discussion in 'Plasma TVs Forum' started by stormjai, May 12, 2005.
  1. stormjai
    stormjai
    Nov 15, 2003
    329
    Bromley
    +3
    This was discussed a year ago, when I was buying Pioneer 434, but can't find threads now..
    the media box has component and HDMI on input 3.
    I currently have DVD, XBox, PS2 going to component via switch box
    I seem to remember that if HDMI connected, the component doesn't work, ie one of the cables have to be pulled out!! :(
    reason for the question, I was going to get new Sammy 850/950 fro HDMI connection, but not if I have to keep pulling out cables!!
    Anybody have experience of this?? :lease:
    It may be same with new Pio 435??
    Jai
  2. loonatic
    loonatic
    Jan 4, 2003
    1,877
    41
    Springwell Village, Gateshead
    +16
    Can you not select between the two inputs via a menu option ?
    Cheers, Lee
  3. NonPayingMember
    NonPayingMember
    Previously Liam @ Prog AV
    Oct 18, 2002
    8,516
    Kent
    +830
    On the 434 component and HDMI are the same input (3). You will need to keep going into the Home Menu and disabling/enabling HDMI each time you switch between component sources and HDMI sources.
