Pioneer MDE / HDE ?
Discussion in 'Plasma TVs Forum' started by voodooflux, Jan 21, 2005.
  1. voodooflux
    voodooflux
    Nov 2, 2002
    267
    Redditch, UK
    +12
    Ello
    Can anyone summarise the difference between the Pioneer PDP-505XDE (lastest 50" model on the Pioneer site) and the PDP-504HDE (listed in the reviews section above)?
    Am I right in assuming that the XDE is just a newer model, or is there more to it?
    v.f.
  2. jwramsay
    jwramsay
    Sep 7, 2004
    1,628
    West of Scotland
    +71
    7 Billion as opposed to 1 Billion colours (wow).
    Built in Freeview box.
    Optical Digital IN.
    Can use HDMI & Component at the same time, on the 4 you choose one or tother.
    Plastic screen rather than Glass screen, saving weight.
    Can't think of anything else. The 5 series replaces the 4 series.
  3. voodooflux
    voodooflux
    Nov 2, 2002
    267
    Redditch, UK
    +12
    Thanks for that.
    I've noticed that Pioneer also have an FDE model (only a 43" variant at the moment though) - is that the same panel as the 43" XDE but without the freeview box?
    v.f.
  4. jwramsay
    jwramsay
    Sep 7, 2004
    1,628
    West of Scotland
    +71
    FDE loses the freeview and a lot of other features:
    1) Beautiful Brushed aluminium remote replaced with cheap plastic job.
    2) PC input on front of Media Receiver dropped.
    3) Media Receiver now 100% black rather than sexy black/silver mix.
    4) Picture in picture dropped.
    5) PCMCIA card holder removed.
    It is quite a bit cheaper than the XDE though. You pays your money I suppose!
    So much easier with the 434/504 range!!
  5. voodooflux
    voodooflux
    Nov 2, 2002
    267
    Redditch, UK
    +12
    Cheers again. Getting seriously tempted by the Pioneer PDP-505XDE now :)
    cheers
    v.f.
  6. binda
    binda
    I've had a Pioneer-505xde for just over a month now and i have to admit its a excellent plasma. The picture is just so sweet especially dvd through the hdmi.
    I'd recommend it to anyone.
  7. Andrew46
    Andrew46
    Hi Voodooflux
    I saw your question was the difference between 504HDE and 505XDE, but the heading was MDE or HDE. Assume you mean the former.
    Glad you are asking - it was my question too. From what I can tell on the Pioneer website another difference in specifications seems to be that the XDE specs mention a digital tuner (but the 504HDE does not).
    I am not too technically minded and have been doing my homework on what to go for - I too am tempted to get the 505XDE.
    Interested to know if anyone thinks there is a better 50inch than the 505 XDE out there at the moment (and reasons why).
    Andrew46
  8. voodooflux
    voodooflux
    Nov 2, 2002
    267
    Redditch, UK
    +12
    Hi Andrew
    Yep, you're totally correct, I meant XDE rather than MDE - apologies for the confusion.
    Definitely like the look of the XDE - heard some good comments about it, and from what I've seen of the 43" variant the picture is excellent, with no trace of jerkiness (is that a word?) when panning across scenes.
    v.f.
