Pioneer Kuro checking for new software and channels?
Discussion in 'Plasma TVs Forum' started by Ireland, Mar 8, 2018.
  1. Ireland
    Ireland
    Nov 25, 2012
    67
    11
    I'd like a way to stop this happening every day. Anyone know how to stop this?
    [​IMG]
  2. JayCee
    JayCee
    Jan 20, 2004
    23,187
    Lanarkshire
    +2,483
    Have you had a look through the set's menu?
    What are you using as a signal source?
  3. Ireland
    Ireland
    Nov 25, 2012
    67
    11
    The first thing I tried. Surely the option must be in the menu somewhere, but I cannot locate it :-(
  4. JayCee
    JayCee
    Jan 20, 2004
    23,187
    Lanarkshire
    +2,483
    What's the model no of your Kuro?
  5. Ireland
    Ireland
    Nov 25, 2012
    67
    11
    PDP-LX5090. Apple TV and PS3.
  6. JayCee
    JayCee
    Jan 20, 2004
    23,187
    Lanarkshire
    +2,483
    Read page 43 of your user manual. “Using Software Update”
    The manual is easily found with a Google search if you don't have it.
  7. Ireland
    Ireland
    Nov 25, 2012
    67
    11
    Thanks for the heads up. That setting seems to be greyed-out and the menu reads: “Current settings do not allow selection and adjustment”.
  8. JayCee
    JayCee
    Jan 20, 2004
    23,187
    Lanarkshire
    +2,483
    It may be greyed out if you’re not on the DTV source...make sure you’re not on an AV input when you try to access it.
  9. Ireland
    Ireland
    Nov 25, 2012
    67
    11
    You wouldn’t happen to know how I get on the DTV source? I tried channel 1, for example, to no luck. I’ve no channel on 1.
  10. invisiblekid
    invisiblekid
    May 10, 2009
    4,689
    4
    +3,600
    3rd button from the top right corner.
    That will get you to the digital TV section. If you have never used the DTV you will need to set it up. The I assume the software update will be available.
    Never used it myself so cannot say for sure if this will help
  11. Ireland
    Ireland
    Nov 25, 2012
    67
    11
    Unsure what button you are referring to, but I found a TV/DTV button near the middle of the remote and was able to I believe now turn off auto software update. Time will tell, but this looks promising. Thanks everyone for your help. Esp. JayCee
  12. invisiblekid
    invisiblekid
    May 10, 2009
    4,689
    4
    +3,600
    On an LX5090? Dunno then, but that was where my button was.
