Pioneer Head Unit Display - Please Help !!!
Discussion in 'ICE, Sat Navs & Dash Cams Forum' started by Dallan, Jun 5, 2005.
  1. Dallan
    Dallan
    Hi I have an older KEH-8200 head unit which works perfectly except that the display is very dim lit (maybe a backlight problem ??) would anyone have any ideas please before I need to change the unit :eek: I did hear there is a dimmer in the menu but I've checked everywhere inc the manual, but nothing - Thanks for any help
  2. Crocodile
    Crocodile
    Nov 4, 2002
    15,164
    +4,479
    Is the display dim at night as well as day? Don't know this model but there's probably a feed from the light switch to dim at night. Maybe this is permanently on via a short or mis-wiring.
  3. figrin_dan
    figrin_dan
    Jan 9, 2003
    1,992
    +135
    I also have an old Pioneer, KEH???? can't remember the model number. The display suddenly whent dim one day about 5 years ago - No dimmer in my functions menu. Sounds like they have bad backlights then.
  4. Ayub
    Ayub
    Oct 15, 2003
    6,374
    Bradford
    +577
    ribbon cable common on the pioneer range £15 - £25 repair
