Struan
Is it possible to replace the DVD drives inside older Pioneer HDD/DVD recorders e.g. 720H, 920H, 930H?
Do you need to source the same, long-since discontinued, drives, or can alternatives be used?
Is it a simple case of removing the faulty drive, and 'dropping in' the replacement, or is a service remote required?
