pioneer fw v3.0
Discussion in 'Blu-ray & DVD Players & Recorders' started by kendisred, Jun 16, 2009.
  1. kendisred
    kendisred
    Aug 6, 2006
    140
    hull, united kingdom
    +3
    :hiya:i have tried to install this to my pio600 , but when i try to play dvd - dvd shut off, i have waited 10 min before restarting dvd as quoted FAQ for Pioneer DV-600AV anyone else installed this firmware and if so how did u do it , i have installed previous version before- i am using nero 7 premium to burn:suicide:
  2. Hkan
    Hkan
    When did you download this?
    There was a problem like this, but it should have been fixed!!
  3. kendisred
    kendisred
    Aug 6, 2006
    140
    +3
    :mad:downloaded this several times this week , but it still crashes:suicide:
  4. Hkan
    Hkan
    Hm, very strange!:confused:
    Well I tested the version I have on my computer and it works OK for me.
    I uploaded it to the server again!
    You can see that it is a different version as I changed the file browser!
    I also checked the version that was on the server and it seems to have the right date and time on it.
    After you installed it and the player have restarted.
    Turn the player off, press and hold the STOP button and then press the STANDBY/ON button, it is the buttons on the player it self that should be used! Keep the STOP button pressed till you see CLEAR on display.
    This will reset the player.
    hopefully this will now work OK for you!
  5. kendisred
    kendisred
    Aug 6, 2006
    140
    +3
    :hiya:i have followed the instructions when i installed firmware but player does not restart it just say loading, i have waited the 10 minutes , so i close i the disc tray and disconnect from mains ,but it still crashes, i will it give another go , if no joy i will stick to v2.2:suicide: thanks for help
  6. kendisred
    kendisred
    Aug 6, 2006
    140
    +3
    :hiya:update , tried again still no joy:thumbsdow, dvd starts to play but when i press fast forward/skips chapter it freezes. hopefully some new firmware may do job hopefully:(
  7. Hkan
    Hkan
    I did find some error in the code so I have now corrected this.
    Hopefully all will work as it should now!
    You're using any firmwares at your sole risk!
  8. kendisred
    kendisred
    Aug 6, 2006
    140
    +3
    hi:hiya: hkan, i installed new firmware , got it to work fine , thanks:thumbsup:, just one minor niggle:lesson:...in audio dsp settings the super bass there is no on/off , plus have u tweaked with any sound levels as my sound is better , or it maybe my ears:clap::clap::clap::clap:
  9. Hkan
    Hkan
    Ah OK!
    I'll look in to it!
