Pioneer Freeview Box problem
Discussion in 'Freeview & YouView' started by KelvinHT, Jul 7, 2004.
  1. KelvinHT
    KelvinHT
    Dec 31, 2003
    330
    Kent
    +13
    I have a Pioneer Freeview box, every time I select BBC1 it takes ages for the picture & sound to come up, it the same for ITV2. Also BBC1 is always breaking up, all other channels are fine.
    Any ideas ?
  2. JefUK
    JefUK
    Mar 31, 2002
    448
    28
    +54
    Pioneer have acknowledged there is a problem with the box. They have already developed a fix and this will be broadcast from 10:00 on 9 July. Make sure the box is set to auto-update.
    I think Pioneer should be congratulated on the speed that they have fixed this problem. If only Nokia were anywhere near as good and quick!
  3. cosmic023
    cosmic023
    Feb 15, 2003
    1,375
    48
    Somerset
    +88
    Yep i'm getting the same problem on my Pioneer box too.
    What channel is the update on ??
  4. Barzo
    Barzo
    May 10, 2004
    1,701
    Liverpool
    +473
    Yes, indeed. I had the same message also. I think you may need to register postal details with them, however. I had to after I gave them the query. I suspect this is so that they can work out whether the problem is nationwide, or only related to certain transmitters. All in all, excellent customer service!
  5. JH4
    JH4
    May 6, 2003
    2,420
    83
    +264
    Yep Mine sometimes won't pick up Beeb1 from the Rowridge transmitter on the IOW.
    Let's hope tomorrow's update will fix it..
  6. JefUK
    JefUK
    Mar 31, 2002
    448
    28
    +54
    cosmic023
    The firmware update is carried on a special engineering channel on Multiplex 1 (BBC). If the Pioneer is set to "auto-update" there is no need to do anything. If the Pioneer is set at the default update time the download will be 03:30 on Saturday 10 July.
  7. Daftboy
    Daftboy
    Jan 8, 2004
    505
    +12
    Not sure if it's the same problem, but my Goodmans GBD2 takes forever to show ITV1.
    Does anyone if this is a firmware bug?
  8. cosmic023
    cosmic023
    Feb 15, 2003
    1,375
    48
    Somerset
    +88
    Cheers JefUK for the tip, it's just that i leave mine in manual mode. (Tends to decide to update when i'm doing a timer recording !! :mad: )
    But when i asked it to look for updates manually, it found an update and loaded it.
    All seems to be ok now, is this the same update you said in your post ??
    From what the update states, it takes care of a problem with BBC1 and ITV2.
  9. DRGL
    DRGL
    Mar 30, 2004
    752
    Shropshire,UK
    If you do a manual update the box on the right of the screen say's the update is to fix the BBC and ITV1 problems ;) Well done Pioneer,1 week from emailing the problem is fixed!!
