PIONEER FM/AM digital synthesized TUNER [F-443L] £25 + £8 postage
Discussion in 'Hi-Fi Stereo Systems & Separates' started by sneale, Jun 12, 2005.
  1. sneale
    sneale
    May 3, 2003
    616
    The 'shire
    +5
    FM Tuner Section
    Frequency range 87.5 MHz to 108 MHz
    Usable Sensitivity 14.2 dBf, IHF (1.4^V/75H)
    50 dB Quieting Sensitivity Stereo; 36.2 dBf,
    IHF (17.7^V/75ft)
    Sensitivity (DIN) Mono; 0.9^V/75ft
    Stereo; 50^V/75
    Signal-to-Noise Ratio Mono; 80 dB (at 80 dBf)
    (SILENT SERVO ON) Stereo; 78 dB (at 80 dBf)
    Signal-to-Noise Ratio (DIN) Mono; 66 dB
    Stereo; 60 dB
    Distortion 0.4% (1 kHz)
    Alternate Channel Selectivity 65 dB (400 kHz)
    Stereo Separation 45 dB (1 kHz)
    Frequency Response 30 Hz to 15 kHz±: 1 dB
    Antenna Input .' 300ft balanced
    75H unbalanced
    AM (MW) Tuner Section
    Frequency range 531 kHz to 1,602 kHz
    Sensitivity (IHF,Loop antenna) 300^V/m
    Selectivity 20 dB
    Signal-to-Noise Ratio 50 dB
    Antenna Loop Antenna
    LW Tuner Section
    Frequency range 15^ kHz to 281 kHz
    Sensitivity (IHF loop antenna) I.OOO^V/m
    Audio Section
    Output
    FM (100% MOD) 650 mV/5.1 k<>
    AM (30% MOD) 150mV/5.1 k.Q
    Miscellaneous
    Power Requirements a.c. 240 Volts , 50/60 Hz
    Power Consumption 10 W
    Dimensions 420 (W)x85.5 (H)x318 (D) mm
    Weight (without package) 3.5 kg
    Furnished Parts
    FM T-type Antenna 1
    AM Loop Antenna 1
    Connecting cord 1
    Operating instructions 1
    NOTE:
    Specifications and design subject to possible modificatior
    without notice due to improvements
    this is in immaculate condition
  2. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,556
    Edinburgh
    +1,265
    What's wrong with the classified section?
  3. sneale
    sneale
    May 3, 2003
    616
    The 'shire
    +5
