Pioneer Elite VSX LX 303 mcacc setting subwoofer to -15db
ckoons1
Pioneer Elite VSX LX303 mcacc setting subwoofer to -15db
wonder why mcacc is setting the subwoofer volume so low after calibration
gain on subwoofer is set to number 6 phase is set to 0 crossover all the way up (not sure crossover setting on sub matters) prior to running mcacc
of course I can adjust the volume manually but should it be done on the subwoofer gain knob or thru the receiver. don't want to run subwoofer too hot
thank you
MaryWhitehouse
First off do you like the resulting sound? If so who care. If not adjust the level on the amp till you do.
ckoons1
I like the sound after I raise the volume on the receiver 10 plus db
just not sure if i am doing something wrong prior to calibration
MaryWhitehouse
All good then :)
MaryWhitehouse
Doesn't sound very likely. Is it running hot?
ckoons1
haven't really checked
being a noob at this I just want to make sure I am doing everything correctly
John7
Let the "auto" adjust everything and then tweak to personal taste.
My LX701 always sets my SVS PC13 Ultra to -14 and I adjust it to -6 which sounds right to me. I also boost the front and rear heights a couple of dB's as it sounds better to me.
The Pioneer app on my iPad is great as it allows you to adjust individual speaker levels in real time
ckoons1
Did you maintain the center speaker volume after calibration?
dante01
wonder why the mcaac is setting the subwoofer volume so low ( -15 )
This is an indication that the subwoofer's own volume on its rear was set too high prior to running the calibration. Prior to the calibration, set the subwoofer's own settings on its rear as follows:
  • Volume/gain to about 10 o'clock and no higher than mideway
  • Set the sub's phase setting tp 0°
  • Set its frequency filter to its maximum setting or set it to a dedicated LFE option if it has one
I'd also suggest you bypass any auto power option the sub may have and set the sub to ON if possible.
You can now runthe calibration
Once the calibration is complete then you should avoid altering the settings on the sub. If you find that the subwoofer level setting on the AV receiver has still been set as low as 15db then you should modify the volume setting on the subwoofer by setting it even lower and then rerun the calibration. You should continue doing this until the sub's level on the receiver is closer to 0db.
You can address the receiver's BASS MANAGENT at this stage and I'd suggest you set all speakers as being SMALL with appropriate crossovers no lower than 80Hz. This is irrespective of the speakers' physical size or their rated abilities. Note that this should be done post calibration because the calibration erases any manual bass management configuration made prior to the calibration.
ckoons1
Awes
You can now ru the calibration
You can address the receiver's BASS MANAGENT at this stage and I'd suggest you set all speakers as being SMALL with appropriate crossovers no lower than 80Hz. This is irespective of the speakers' physical size or their rated abilities. Note that this should be done post calibration because the calibration erases any manual bass management configuration made prior to the calibration.
Awesome. Thank you very much
ckoons1
Had to set the gain switch on the subwoofer to number one in order to get near 0db on the receiver subwoofer calibration. Is that ok to have the gain on the subwoofer set that low?
dante01
It depends upon how close it is to where you are sat and where it is? I'd suggest yes, you'd be better with the sub being at leat 2m from your seating position, ideally located at the front of the room as opposed to having it in so close.
You may find these articles of interest:
ckoons1
at the moment its approx. 7 feet away from the listening position off to the side with rear of subwoofer about 10 inches from the wall. this is the current location before moving it. if I move it, it will be approx. 10 feet from listening position, facing forward and approx. 2 feet from the wall next to center speaker.
would one be better then the other or would it be irrelevant
ckoons1
currently having trouble with my mcacc mic getting a mic error. not able to test different sub placings yet
kvtbucs113
thank you
mine was around -30 db and said like 30 ft away in reality the sub was only 8 ft from map. i got a question for you guys . my sony upb x700 streams in atmos audio and my reciever say so but when I play a 4k blu ray disk my bd player says true hd audio but reciever said normal dd sur and my TV usually says atmos (audio out) when str a aming but only dolby with disk any help
Latest News
What's new on UK streaming services for December 2021
  • By Andy Bassett
  • Published
Best Projectors of 2021 - Editor's Choice Awards
  • By Steve Withers
  • Published
Black Friday 2021: What you need to know
  • By Andy Bassett
  • Published
What's new on Blu-ray Special - The Cinema of Zhang Yimou & Gong Li
  • By Mark Costello
  • Published
AVForums Podcast: 24th November 2021
  • By Phil Hinton
  • Published
