Pioneer Elite plasma: brightness problem?
Discussion in 'Plasma TVs' started by Boleros, Apr 23, 2005.
  1. Boleros
    Boleros
    My pioneer elite 50" plasma is only about 10 months old, but begining 4 months ago, I started to notice that in some movies where there is high contrast, the tv appears to spontaneously shift levels of brightness at a rate of 1-2x/minute...it's becoming quite irritating.
    Has anyone experienced this? Hopefully its some kind of setting issue and not a serious problem with my equipment. Btw, my source is a Denon 3910.
    Thanks,
    B
  2. dvdsubtitles
    dvdsubtitles
    just occurred to me - have you got the plasma set to "economy" power mode? in this mode it tends to dynamically shift brightness levels in order to keep contrast and power consumption to a minimum. I'm sure this was mentioned on a thread here a few months ago.
    Got the same plasma (I think - PDP-504HDE?) and there is an "economy" power setting, cant remember exactly where.
    Mat
  3. Boleros
    Boleros
    Thanks for your suggestion.
    I checked, and the power setting is on "standard," not on "save."
    My model number: Pro-1110HD
    Please let me know if you think of anything else.
    Thanks,
    B
  4. laser
    laser
    Aug 1, 2004
    924
    Hartlepool
    +28
    Have you got any of your picture settings set to automatic or dynamic?
    I have a Hitachi plasma and had a similar problem. The contrast on the plasma was set to dynamic and the contrast would shift during certain films. It looked horrible.
    I have since set the picture settings manuallyand it went away. No more problems and the display looks a lot better than using the predefined factory settings.
