pioneer dvs5 ntsc to pal60
Discussion in 'Blu-ray & DVD Players & Recorders' started by filmman, Jun 14, 2003.
  1. filmman
    filmman
    Nov 10, 2001
    237
    brighton
    +4
    hi
    i have a techtronics e-mod dvs5 and i was told it would output pal60 from ntsc discs,ihave checked the techtronics site but i can find no info.there is no switch on the back,so how do you get pal60 output?
  2. ferris57
    ferris57
    Jan 18, 2003
    869
    I would guess just leave it set to pal in the setup menu?
  3. filmman
    filmman
    Nov 10, 2001
    237
    brighton
    +4
    hi ferris57
    i cannot find any menu for altering to pal60 output ,is it a hidden menu?
  4. ferris57
    ferris57
    Jan 18, 2003
    869
    I wouldn't think so. What options are in the setup menu?
    Is there not a pal/ntsc/auto option in the video or display section of the setup menu?
  5. ferris57
    ferris57
    Jan 18, 2003
    869
    Oh and was it bought from techtronics or was it only the mod that was bought from techtronics? seemingly the diy mod or upgrade fitted by them alone doesn't allow pal60.
  6. Family Guy
    Family Guy
    I know with the later Pioneer models you press and hold skip fwd and skip rev on the front of the machine, not the remote, at the same time. With the buttons held, turn the player on and keep them held down. The player will do it's thing and it should either read Pal, NTSC or auto on the display. If you want it to output Pal 60, just repeat this process until it says Pal in the display.
    I know for a fact that this works on a Pioneer 525, 444 and 350 but whether it works or not on your model is something you'll have to try mate...
  7. filmman
    filmman
    Nov 10, 2001
    237
    brighton
    +4
    hi
    thanks to you all for the feedback,it looks like the player has been modded by techtronics but not supplied by them,hence no pal60 output(as claimed by seller).no good to me as my tv will not take pure ntsc so looks like player will be up for sale.
    thanks.
  8. shoestring25
    shoestring25
    Feb 2, 2003
    3,338
    essex
    +209
    just switch it to pal if it outputs a picture from a region1 ntsc disc while switched to pal it is diplaying a pal 60 picture. it should have this described in the instruction manual
    cheers
  9. Family Guy
    Family Guy
    :confused: :rolleyes:
    The guy was actually asking HOW to switc it to Pal...if he new how to do it, do you not think he would...?:rolleyes:
