Pioneer DVR5100HSMR - any good?
Discussion in 'Blu-ray & DVD Players & Recorders' started by leewhite1974, Oct 28, 2004.
  1. leewhite1974
    leewhite1974
    I've been thinking of buying a hard drive/DVD recorder for ages. I've finally decided on the following model, Pioneer DVR5100HSMR, seen at the following link:-
    http://www.empiredirect.co.uk/conte...PIO-DVR5100HSMR
    Does anyone know if it's any good compared to other models, and whether it can pause live TV.
    Thanks in advance.......
  2. Monza
    Monza
    The Pioneer DVR-5100 is an old model and in the meantime replaced by the DVR-520HS (and DVR-720HS). So if you want to buy a Pioneer, it think it's recommended to buy the new generation instead of an old machine...
  3. ernet
    ernet
    Moreover 520 has RGB IN, slightly changed menu , A-B erase and sth. else I don't remember. Go for it.
