Pioneer DVR433H....which burner and firmware does it have??
B
beatlefan
I've had this fabulous machine for about six months now but i want to find out which burner it has in it?, which firmware it has, and if theres a firmware update available?
Anyone know how i can do this?
Thanks In Advance guys.
H
Hkan
How to check for what firmware version your DVR has do the following:
Via the remote, from the Home Menu, go to Initial Setup, then select Audio Out, select Digital Out, highlight the "On" setting (i.e. don´t click enter just make sure it is highlighted), then press the Angle button, the firmware versions are now shown.
Lastest firmware version i know of to the DVR-433 is:
Version: 4.39
SYSCON RELAESE: 462
TUFLCON; 855.004
DRIVE: 1.59
The burner should be a modified DVR-109
