Pioneer DVR420H compatitility with pc created discs
Discussion in 'Blu-ray & DVD Players & Recorders' started by No-One, Apr 25, 2005.
  1. No-One
    No-One
    Nov 6, 2004
    161
    Rutland
    +12
    Has anyone had any problems getting this player/recorder to play discs created on a pc drive? I'm using a Pioneer dual format dvd burner on my pc. I've tried creating 2 backup discs on the pc onto Sony DVD-RW discs. Both times I put them into the Pioneer to have it just display the message "Cannot play this disc". They play back fine on the pc. The strange thing is that if I do exactly the same thing on the pc but using a Philips DVD+RW (a disc that the pioneer isn't supposed to support at all) it plays the film perfectly. What's going on?
  2. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    12,846
    Somewhere in South Yorkshire
    +5,078
    Not an expert on DVD writing, but this type of issue can occur when a recorded disc isn't "finalised". I gather that DVD+RW don't need it, but DVD-RW do.
  3. greyhorse
    greyhorse
    Apr 16, 2005
    445
    Try a dvd-r disk, these are more compatible with most home players.
  4. No-One
    No-One
    Nov 6, 2004
    161
    Rutland
    +12
    The -rw discs were finalised by the pc. Not got any -r discs to try. Odd thing is that when I try the discs supplied with the player called "Zero Defex" it works perfectly. The 420 can record to the sonys itself and playback what it's recorded withot any trouble.
