Pioneer DVR series does not recognise NTSC in
Discussion in 'Blu-ray & DVD Players & Recorders' started by DeadMan3000, Dec 20, 2004.
  1. DeadMan3000
    DeadMan3000
    It will take PAL in on AV2 fine but not NTSC.
  2. eddyad
    eddyad
    Jan 5, 2003
    940
    Hampshire
    +9
    Check Input Line System. It's on page 98 of 420/520/720 manual, in the Initial Setup chapter
  3. DeadMan3000
    DeadMan3000
    That's interesting. You can only record in S-Video mode in NTSC then.
  4. eddyad
    eddyad
    Jan 5, 2003
    940
    Hampshire
    +9
    If RGB is not in the list - yes. but that would be because RGB is unknown in the US. All their video is 's' or composite, and probably now component.
    RGB is mainly European.
  5. stevestarr13
    stevestarr13
    Jan 15, 2004
    Aberdare
    Hi Deadman
    thanks for all the help recently, have you been able to get your 220 to record US videos yet? I am going to try tomorrow any tips would be appreciated as to settings. I am hoping to use a scart to do this, got one off Multi region to remove macro so I hope all will be well
  6. phelings
    phelings
    Jul 24, 2003
    1,025
    36
    Pioneer will also record PAL 60 as output by UK vcr when playing NTSC vhs.Line input still needs changing
  7. DeadMan3000
    DeadMan3000
    Yes I tested recording a Region 1 DVD (Naughty). No problem.
  8. stevestarr13
    stevestarr13
    Jan 15, 2004
    Aberdare
    worked a treat
