Pioneer DVR 720 H Compatability query
Discussion in 'Blu-ray & DVD Players & Recorders' started by Paul Bates, Jul 31, 2005.
  1. Paul Bates
    Paul Bates
    I have a Pioneer DVR 720 H which I use to record tv programmes on. It works great, but although I finalise each DVD after recording I am unable to play back the programmes on my other DVD player, which is a Pioneer DV-U7.
    Am I doing something wrong here?
    Paul B
  2. Rasczak
    Rasczak
    Apr 3, 2002
    21,710
    Warwick
    +2,586
    Your Pioneer should be able to play your media fine - so there is obviously a problem. What media are you using? If it is DVD-R then it should work. If DVD-RW then you need to ensure you are using Video mode and not VR mode.
  3. Paul Bates
    Paul Bates
    Thanks for your advice. I use DVD-RW. Switching to video mode does the trick. At the risk of sounding dim, is there any way to salvage the stuff I'd already recorded (via VR mode) so that I can play those discs on other machines or do I need to start from scratch?
    Thanks again.
  4. Rasczak
    Rasczak
    Apr 3, 2002
    21,710
    Warwick
    +2,586
    You can dub them back to the HDD of your 720 and then dub to a Video formatted DVD-RW.
  5. Paul Bates
    Paul Bates
    Thanks once more, you know how it is, sometimes you can't see the wood for the trees!
