Pioneer DVR-630H-S vs. Sony RDR-HX910. Help deciding
H
hardwarefanatic
Hi:
I am trying to decide which one of these two DVD recorders with HDD to buy.
I have read the manuals and can see that both of them have almost the same functionalities apart from the HDD size but still have some questions:
1.- Does the Sony RDR-HX910 have 2 scart connections on the back just like the Pioneer?. Maybe this is a silly question but the manuals i have read so far are a little confusing :(
2.- Can i edit the recording to cut out the ads with the Sony model? I understand this is possible with the Pioneer.
Any other suggestion is much appreciated :)
A
ArtS
Yes, it has two scarts.
Yes, you can.
ArtS :cool:
eddyad
Established Member
If you are a Freeview, satellite or cable viewer you may like the GuidePlus facility on the Pioneer. You set the timer on the recorder (it downloads a guide for you) and if it's a non-analog channel it will control the set top box with an IR transmitter. Then you don't have to set the timer on the STB. There is a list of compatible STBs on http://www.europe.guideplus.com/
(But maybe the Sony has it too).
foneman
Established Member
the major difference is that the sony does not save thumbnails to a DVD... there is also some issue with widescreen switching, search the forum to check this out...
the pioneer 630 has a choice of different thumbnail layouts to choose from..
both have great quality, it is really up to your personal prefs...
forum about other probs...
http://www.avforums.com/forums/showthread.php?p=2156571#post2156571
Rocky 4K, Creed 3 and boxing movies, Shazam 2, 65 trumping Jurassic World Dominion, + Picard & Mando
