Pioneer Dvr 520hs widescreen switching
Discussion in 'Blu-ray & DVD Players & Recorders' started by jmgraham, Feb 11, 2005.
  1. jmgraham
    jmgraham
    Jan 30, 2005
    40
    11
    Dundee
    +4
    I've got a problem with my pioneer dvd recorder, i have the sky digibox connected to AV 2 input and philips widescreen tv (32pw9505) connected to AV 1 output using fully wired scarts as per manual. When the dvd recorder is in standby if i swtch from a widescreen channel to a 4:3 channel the tv will automatically resize to the correct aspect ratio but when the dvd recorder is on it will not automatically change the aspect ratio, (i have to cylcle through the inputs to get it to set correct aspect ratio). I have input and output on dvd recorder set to RGB. When i set input to composite video it will switch the tv aspect ratio ok.
    I have tried different scart cables - no difference, wondering if ive got a fault or if anyone else with similar setup has experience this.
  2. MikeMcr
    MikeMcr
    Jan 8, 2003
    401
    Manchester, UK
    +16
    http://www.avforums.com/forums/showthread.php?t=167412
