Pioneer dvr-520h (high speed problem)
Discussion in 'Blu-ray & DVD Players & Recorders' started by compuman, Apr 4, 2005.
  1. compuman
    compuman
    I buy this dvd-recorder this friday...
    I have a problem!
    If I use HDD-DVD high speed copy with Verbatim DVD-R 8x the disc is unreadable... (I make 4 test)
    All ok with sony and nashua dvd-r 8x
    Is this normal ?
    Or I have to take back the dvd-recorder for another one?
    I have some problem also with tdk dvd-r 8x, all ok with dvd-r 4x (many brand)
    Question:
    can I limit the write speed to 4x ?
    Exists a firmware that do this?
    or a hidden menu?
  2. pinatubo
    pinatubo
    How did you obtain your Verbatim disks?
    Did you buy them as individual disks in cases or on a spindle of about 25/50 disks.
    The 2 types of disk have different dyes since they are made in different factories - the ones on a spindle have a lower quality dye (CMC I think) compared to the individual disks (MCC?)
    I think Sony disks are MCC.
  3. phelings
    phelings
    Jul 24, 2003
    1,025
    36
    I also had problems with about 4 out of 50 Verbatim spindled discs.
    I have switched to TDK spindles.
    You can limit copying to 4x by buying only 4x discs
  4. compuman
    compuman
    pinatubo:
    my Verbatim are on a spindle of 25 discs
    and on another spindle of 10 discs
    all the same problem
    The id disc is: MCC 01...
    The Sony id disc is: Sony08...
    phelings:
    I have some problem also with a tdk dvd-r 8x disc...
    No problem with sony, philips(fujifilm03) and nashua
    I am confused...
    Is this normal or I have to take back my dvd-recorder?
  5. ktng
    ktng
    May 9, 2004
    171
    16
    UK
    Well this is 4x media code. so if your Verbatim was sold as 8x it could be fake, which would explain your failed burns.
  6. compuman
    compuman
    sorry, i write wrong id:
    verbatim dvd-r 8x have MCC 02RG20
    nothing to do... all I write is unreadable
    NB
    i notice a circle on the bottom of the discs (on burned disc)
    if i burned with differend writer the circle there isn't...
    :eek:
  7. pinatubo
    pinatubo
    Can you burn these disks properly in real-time as opposed to High Speed?
    If you can then I would suspect that the media isn't as good as Verbatim let us believe.
    Unfortunately I don't know of any way to slow down the burn speed on the Pioneers.I have the 420 and havn't tried to use Verbatim 8X disks - I'm currently using Ritek 4X disks with no problems either using High Speed or Real-time copying.
  8. compuman
    compuman
    Yes, I can burn it in real time...
    I can burn other dvd-r 8x in high speed copy
    So I think that the problem are the verbatim dvd-r 8x
    :thumbsdow
    Now I try Verbatim dvd-r 16x. The dvd-recorder don't see me as 8x so burn them at 4x.
    The disc is write correctly!!!
    :clap:
    So I think that the quality of verbatim dvd-r 8x is poor
    :nono:
  9. compuman
    compuman
    I post the results of test on many media that I found in my city
    BRAND Media code Result
    PHILIPS 8x (write at 8x) FUJIFILM03 OK
    SONY 8x (write at 8x) SONY08D1 OK
    NASHUA 8x (write at 8x) PRODISCF01 OK
    MAXELL 8x (write at 8x) MXLRG03 OK
    NASHUA 4X (write at 4x) MCI4XG01 OK
    VERBATIM 16X (write at 4x) MCC03RG20 OK
    TDK 16X (write at 4x) TTH02 OK
    VERBATIM 8X (write at 8x) MCC02RG20 NO, UNREADABLE
    my firmware is:
    version: 2,71
    syscon: release_156
    tuflcon: 2,25M
    drive: 1,19x
    device: prism-plus
    region: 2
  10. eddyad
    eddyad
    Jan 5, 2003
    940
    Hampshire
    +9
    Thank you for posting these results. You have obviously spent some time testing and the information is very useful.
  11. ktng
    ktng
    May 9, 2004
    171
    16
    UK
    Yes thanks for posting your results. I will try some MCC02ORG20 discs that aren't Verbatim and see if they are ok in my 520.
    BTW - how do you find out which firmware you have :lease:
  12. compuman
    compuman
    Here are the instructions to get the firmware:
    Press "HOME MENU"
    Choose "Initial Setup"
    then "AUDIO OUT"
    Put "DIGITAL OUT" to "OFF"
    Press "RIGHT" button
    Then the "ANGLE" button
    NB
    I don't "put digital out to off"... and it work
    Please tell me your firmware version
  13. ktng
    ktng
    May 9, 2004
    171
    16
    UK
    my firmware is:
    version: 2.64
    syscon: release_123
    tuflcon: 2.25M
    drive: 1.13W
    device: prism-plus
    region: 2
    Burnt 2 MCC02ORG20 discs (both Datawrite silver printable). They both play back fine in the 520 and my Pioneer 575. However they both give read errors in my Liteon DVD-Rom using Nero CD-Speed, but read back fine in my Pioneer 107 DVD burner using Nero CD-Speed.
    Not very conclusive I'm afraid - I guess that the failure in the DVD-Rom means that there may be playback problems in some DVD players.
  14. mattross
    mattross
    Oct 23, 2004
    257
    +6
    I have:
    version: 2.69
    syscon: release_146
    tuflcon: 2.25M
    drive: 1.16E
    device: prism-plus
    region: 2
    Does anyone know if it's possible to download a firmware upgrade CD or is paying for it the only option? If I knew the update was worth it then I would buy it.
  15. compuman
    compuman
    So I have the last version
    i would like to know if pioneer can help us...
  16. mattross
    mattross
    Oct 23, 2004
    257
    +6
    Compuman has a later firmware, see post #9 above.
  17. ktng
    ktng
    May 9, 2004
    171
    16
    UK
    Yes but Compuman has a 520 and you have a 420, so how do you know you don't already have the latest firmware.
