Pioneer DVR - 440HX-S Problems
Discussion in 'Blu-ray & DVD Players & Recorders' started by Gezzerboy, Sep 22, 2007.
  1. Gezzerboy
    Gezzerboy
    Oct 10, 2005
    34
    I have a Panny 440HX recorderd and totally love. Had it for just over 1 yr but all of a sudden it has stopped responding to the remote.
    I though the remote was damaged so replaced batteries and then bought a new universal remote but it fails to respond. It starts up plays disks turns off all from manual controls but i obviously need guide and record options to work.
    Totally gutted. Does anyone have any ideas.
  2. Gavtech
    Gavtech
    Administrator
    Oct 25, 2005
    21,145
    +7,093
    Welcome to the forum.
    Surely that is a Pioneer machine not Panasonic.
    I am not familiar with Pioneer machines, but normally DVDR's have an optional 2 or 3 remote codes so that more than one machine can be controlled in the same room.
    If the unit possesses this feature, it is possible that the main unit's code has been inadvertently switched.
    Have a look in the manual to see if you can find out whether such facilities exist and how to change the code of either the machine or the remote so that they match.
    Alternatively, and probably recommendable, reset the machine to factory condition and it should respond to one of your controls.
    If it does not, then it is reasonable so suppose the unit has a fault.
    Not likely to be an expensive one to put right.
  3. Gezzerboy
    Gezzerboy
    Oct 10, 2005
    34
    Yes your right apologies dont know what i was thinking.
    I have done a hard reset on the player but still no good. Just wont respond to the remote. I know the remote works though as my universal remote picks it up when learning.
    Anyone know where i could get this repaired
  4. Tony Lazzerini
    Tony Lazzerini
    Jul 7, 2007
    967
    43
    +240
    Pioneer's website has a list of authorised service centres. Pick the one nearest you and give them a call. If the unit is less than a year old it will be repaired FOC.
    Tony
