Pioneer DVR 440 HX-S
zak smith
got a Pioneer DVR 440 HX-S it says in the manual it can play
DivX but i can not get any to work but they all play fine on my
Pioneer 696 Player
Any ideas folks
ChainsawDude
any one please
What sort of disc are you trying? e.g. CD-RW, DVD+R etc
What format are you using? e.g. ISO, UDF 2.0 etc
What codec is the DivX?
What happens when you try? any message etc
DivX works OKish on mine, there are times when you have to try hard e.g. I had one DivX that would play only when it was the only file on the DVD. Other people have more luck with DVD-RW than +RW.
Northerner76
I have this model and it played Divx authored onto a CD just fine!! I didn't create the DivX (it was SD season 3 LOST downloaded by a work colleague)
so can't advise on why yours it not working or any potential incompatibility... just wanted to let you know it does work :)
Pioneer 696 Player
Any ideas folks
zak smith
ive been puting the same stuff pre done divx not done myself on a dvd and it says canot play disc was on a dvdr+ im going to put Battle Star galaktaka on a dvdr-
it worked folks DVDR- and cdrw
NOT DVDR+
