Pioneer Dvr-420h - Dvd Recording Problem
Discussion in 'Blu-ray & DVD Players & Recorders' started by fred the ted, Jun 27, 2005.
  1. fred the ted
    fred the ted
    I am currently experiencing a problem when attempting to record TV onto a DVD via 'TIMER RECORD'.
    When inputting you are given the option to record either by 'DVD or HDD'. But despite choosing the 'DVD' option , and double checking, the item records onto 'HDD'. I then have to rush and record onto 'DVD' manually which defeats the object of using timer.
    Has anyone else had the same problem or am I doing something stupid?
    Chers.
  2. eddyad
    eddyad
    Jan 5, 2003
    940
    Hampshire
    +9
    There are a few possibilities.
    1. The length of the program may be too great for the recording mode that is set (e.g SP). You need to set a different mode or use Auto - page 49 in manual. Also see Note on page 52 about Optimized
    2. I don't think you can record to DVD if you are using PDC - but I can't find the note in the manual.
    3. Is Lock Disk 'On' - page 92?
    Pioneer's Tech Help is very good - Pioneer UK phone number is 01753 789 789
  3. pinatubo
    pinatubo
    See the reply over on your post on digitalspy.
    HDD light illuminates but the recording is being made on the DVD - not the hard disk.
  4. fred the ted
    fred the ted
    Many thanks for your replies and will try again tonite.
